device enrollment notification - even though device is already enrolled...
jhaff
New Contributor III
we have been deploying new M1 macbook air machines since July.  we changed our deployment workflow this year to use a workflow in MDS to deploy the os (big sur) and packages (instead of pushing packages/policies over the air through JAMF).  we skip the setup assistant and enroll into mdm through user enrollment.
we haven't had any issues except that recently our users started getting the device enrollment notification saying that our organization can automatically configure their mac... even though they have the mdm profile installed and we're actively managing machines through JAMF.
has something changed in big sur where this is now expected behavior?  i should hope not... any insight would be appreciated.
1 ACCEPTED SOLUTION
wmehilos
Contributor
Do those Macs have PreStaged applied to their serial numbers?
2 REPLIES 2
wmehilos
Contributor
habib_leon
New Contributor
I have the same issue, the macbook is enrolled via PreStage enrollment and a pop-up message appears that Device Enrollment ( Company can automatically configure your mac) even was already enrolled, did someone find the solution how to remove that message?
