Distribution Point in Inventory?
clifhirtle
Contributor II
I must be missing something... is there no way of knowing/collecting inventory on what distribution point clients are reporting to? I see the option to set the DP on either default or per-policy levels, but no option of actually reporting on it later on? Not seeing any extension attribute template here either.
Suggestions?
2 REPLIES 2
clifhirtle
Contributor II
OK judging from post below appears reporting may not be possible, but setting by subnet is. That may be sufficient for what we need right now.
https://jamfnation.jamfsoftware.com/discussion.html?id=5157
donmontalvo
Esteemed Contributor III
I always thought Casper would be able to automagically route clients to their nearest Distribution Point. Apparently not. JAMF gave us a cool subnet import tool a while back, and so its easy to import subnets. But trying to manage which subnets use which Distribution Point would be a huge task. Maybe this should be a feature request? :D
https://donmontalvo.com
