Posted on β05-30-2016 08:53 AM
Good Morning or Afternoon
I am using Dockutil for my lab computers. Here is a portion of my dockutil script
sudo -u $3 /usr/local/sbin/dockutil --remove 'Mail' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'Launchpad' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'Maps' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'Reminders' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'iBooks' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'FaceTime' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'App Store' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'iTunes' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'Messages' --allhomes
sudo -u $3 /usr/local/sbin/dockutil --remove 'Contacts' --allhomes
/bin/sleep 5
sudo -u $3 /usr/local/sbin/dockutil --add /Applications/Firefox.app --after 'Calendar' --allhomes
/bin/sleep 5
sudo -u $3 /usr/local/sbin/dockutil --add /Applications/Google Chrome.app --after 'Firefox' --allhomes
/bin/sleep 5
sudo -u $3 /usr/local/sbin/dockutil --add /Applications/Microsoft Word.app --after 'Google Chrome'
When a user logs in for the first time, They get icons added to the dock. Log out log back in the dock may be a little smaller with some of the apps removed. Log out log back in, now almost all of the app I want removed are except maybe Mail or Launchpad. What could I be doing wrong?
Thanks in advance.
Posted on β05-30-2016 09:08 AM
I rebooted the machines. Seems to be working
Posted on β05-30-2016 02:04 PM
You may find it comes back as the machines slow down, I had to put a delay at the front of my scripts for it to work properly on first login.
Posted on β05-30-2016 04:44 PM
We run a script on lab machines at every login to ensure the dock is "default" for all students throughout the semester.
I found that a delay at the start of the script was required.
/usr/local/bin/dockutil --remove all --no-restart
sleep 2
/usr/local/bin/dockutil --add '/Applications/Firefox.app' --no-restart
/usr/local/bin/dockutil --add '/Applications/Safari.app' --no-restart
/usr/local/bin/dockutil --add '/Applications/Adobe Acrobat DC/Adobe Acrobat.app' --no-restart
etc etc etc...
killall cfprefsd
killall Dock
Posted on β05-30-2016 09:16 PM
I ran into a similar problem and tried a delay, but didn't have consistent results in my environment. I made a loop that checked the dock and if the app was missing it would add it. Here is the check component:
dockutil --list --homeloc /Users/$logged_in_user_here | grep "$app_name_here" | sed $'s/ .*//'
If it isn't in the dock, then I have the 'for loop' add it. The sed part at the end grabs the name before the tab character. Typical dockutil list output looks like this:
Google Chrome file:///Applications/Google%20Chrome.app/
The space between 'Google Chrome' and 'file:///...' is a tab.
I thought this was interesting and I love to share fun facts: The $
by sed
is because bash will process escapes, such as
, inside $' '
before passing it as an arg to sed
. Great stackoverflow here about it.
Posted on β05-30-2016 11:58 PM
Not sure if you guys already heard or tried this Dock Master
http://errorfreeit.com.au/blog/2015/4/28/dock-master
I found this a LOT easier to deploy, very consistent so far ever since we used it. No scripting needed.
Please vote on this Feature Request to implement the same technique on JSS
Feature Request 4799
Posted on β05-31-2016 02:36 PM
@Eigger
Dock Master works quite well, however it makes the dock immutable I believe, so good in a classroom, less useful for staff machines for example where people want to chop and change their docks (but you might still want to create a default one for them).
I agree though an enforced dock is certainly something that would be nice to have directly in Casper.
Posted on β03-01-2017 08:37 AM
@stevevalle Good Morning!
I'm just curious how you do run the script at every login. I set it up the way I thought it should work but with no success at all, I'm truly doing something wrong.
Any tip would be greatly appreciated. Have a very great day today!
Posted on β03-01-2017 09:08 AM
Posted on β03-01-2017 01:18 PM
@skinford Hi
I have an ongoing policy set to run at login, scoped to all lab computers (smart group). The policy runs the script.
Once lab computers check in with the JSS, they get our "default" dock!
Hope this helps.
Posted on β03-01-2017 01:48 PM
I've found Dock management much more reliable when "Perform login hook actions in background" is turned off. This way all Dock changes are done prior to the user environment being processed.
Posted on β03-01-2017 02:22 PM
Good to know @cbrewer !
We have been having issues with some login policies are sometimes not running at login.
Will uncheck this and test :)
Edit: Unchecking this doesn't work well with our DEP policies, as the user needs to be fully logged in to receive the splash screen, prompts to input data and so on!
Posted on β03-01-2017 06:27 PM
Interesting I found I had to wait for the user environment to be loaded before messing with the dock, I do this by divorcing the process away and having it wait until it detects the finder before doing the dock. It's a bit ugly as the dock flashes once but it works!
I actually found running login policies in the background improved things simply because the Finder became available 5 to 10 seconds earlier, likewise for a number of other policies I have that wait as well.
Posted on β10-13-2020 02:30 PM
I'm running dockutil on my school environment. However, network users such as students is not getting their dock apps even though there is script running ( Launch Agent ) when user log in. Sometimes, Students have to restart the computer for few times to get the dock setup. Does anybody have a script that works well for dockutil ? Would be much appreciated , if can share with me.
Posted on β10-13-2020 02:32 PM
configureDefaultDock() {
DOCKUTIL=/usr/local/bin/dockutil Sleep 2
$DOCKUTIL --remove all --allhomes
$DOCKUTIL --add '/Applications/Safari.app' --allhomes
$DOCKUTIL --add '/Applications/OneDrive.app' --allhomes
$DOCKUTIL --add '/Applications/Microsoft Word.app' --allhomes
$DOCKUTIL --add '/Applications/Microsoft Outlook.app' --allhomes
$DOCKUTIL --add '/Applications/Microsoft PowerPoint.app' --allhomes
$DOCKUTIL --add '/Applications/Google Chrome.app' --allhomes
$DOCKUTIL --add '/Applications/Adobe Dreamweaver 2020/Adobe Dreamweaver 2020.app' --allhomes
$DOCKUTIL --add '/Applications/Adobe Illustrator 2020/Adobe Illustrator.app' --allhomes
$DOCKUTIL --add '/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app' --allhomes
$DOCKUTIL --add '/Applications/Adobe Lightroom CC/Adobe Lightroom.app' --allhomes
$DOCKUTIL --add '/Applications/Adobe Premiere Pro 2020/Adobe Premiere Pro 2020.app' --allhomes
$DOCKUTIL --add 'smb://8071FS03/Transfer' --allhomes
$DOCKUTIL --add '/Applications' --allhomes
$DOCKUTIL --add '~/Downloads' --allhomes
Posted on β10-13-2020 02:33 PM
Above script is the one that I'm using currently
