Does macOS 10.12.4 REQUIRE Jamf Pro 9.98?
jriv
New Contributor III
I just want to get clarification on this before macOS 10.12.4 comes out. What will happen if we don't upgrade to 9.98 and our clients upgrade to macOS 10.12.4?
5 REPLIES 5
sepiemoini
Contributor III
Contributor III
Very good question. Bookmarking this post. Please clarify, Jamf :)
jwojda
Valued Contributor II
some of the config profile options will require 10.12.4.
RobertBasil
Contributor
10.12.4 does not require 9.98 but some of the new profile options available for 10.12.4 are only available in 9.98
jriv
New Contributor III
Thanks, @jwojda and @RobertBasil.
Are you guys speaking from experience and/or is this documented somewhere and I missed it?
michael_devins
Contributor II
Contributor II
Jamf Pro 9.98 adds new feature support for macOS 10.12.4. According to our testing, there are no changes in macOS 10.12.4 that would require upgrading from 9.97 to 9.98 in order to continue supporting those Macs.
If you do encounter any issues with 10.12.4 once it formally releases, please open a ticket with Jamf Support. Thanks!
