El Caption pre configuration Imaging Simple Solution?
apatterson
I am trying to make an Image or snapshot of El Caption with Composer it's referring me to the recovery drive. The main target hard disk is grayed out and I am unable to select it. Its there a simple or easy way to select this. Is there a simple method other people are using.
My goal is to get a default El Caption Image that I won't have to do a 1st time pre configuration. We are using time machine to setup right now and it's not a process we want to do.
We already have a software library. Disk utility to clone to make an image is over 250 gig this is much to large? Could someone shed some light on a better solution?
1 REPLY 1
MacSysAdmin
Contributor
You need to capture the image while booted from a drive other than the one you wish to capture.
