ESET Endpoint Security and System Extension with Big Sur
ITFRANCE
New Contributor II
Hello,
Indeed I try to limit as much as possible the interaction of the users for the configuration of the antivirus, only by following the following procedure:
https://support.eset.com/en/kb7324-deploy-eset-endpoint-products-for-macos-using-jamf-pro
I must allI always have to approve manually the extension systems in spite of the plist (see the attached picture)
0a26f9dc0a3b46a8bd3455459d6a576b
Do you have a solution to automate this?
Thanks
2 REPLIES 2
dmendonca
New Contributor
We have the same issue. Set up policy as per Eset, but user still needs to approve the extensions..
gaoyajing0810
New Contributor
You can refer to the official documentation and use system extension +PPPC to complete your requirements。
https://support.eset.com/en/kb7718-install-eset-endpoint-for-mac-version-610-remotely-on-macos-big-s...
