Posted on 07-05-2011 10:32 AM
I just got a PDF from Apple with 50 license codes for Final Cut Pro X to download from the App Store. How exactly am I supposed to deal with this from a package-creation standpoint?? Anyone tried this yet?
Thanks,
-lauren
lauren nicholas
User Support & Technology Analyst – Hurd Campus
Center for Information Technology
Moravian College
610 861 1633
Posted on 07-05-2011 11:07 AM
That is, right there, the $64,000 question.
On Jul 5, 2011, at 1:32 PM, Nicholas, Lauren wrote:
--Jim
Posted on 07-05-2011 11:11 AM
Apple must have a solution for you, or they wouldn't have put it in the App Store.
Posted on 07-05-2011 11:22 AM
If Apple treats it like they do Adobe, you can use the same serial for all seats, just having proof that you've bought all 50. My only concern would be some sort of DRM/copy check to see if there's another seat on the network with the same key. Seems like something that your sales rep should be able to answer.
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
Posted on 07-05-2011 01:52 PM
Yeah I got same email but couldnt download on my admin composer mac as my graphics card isn't good enough
Criss Myers
Posted on 01-31-2012 01:59 PM
You can install on one mac then package it. Then this package can be used for multiple Mac deployments. Make sure you have matching number of licenses.
http://support.apple.com/kb/HT4781
