General Check
vantyg619
New Contributor
Need quick general info. Suppose the server where JSS is installed is restarted or is being moved or else, what are the things we need to check if the application is working properly ? And how do we check them ? Example the services JAMF uses etc.
4 REPLIES 4
Johnny_Kim
Contributor II
Tomcat service and MySQL would be two services on a Windows server.
Easiest way to check if the JSS is up and running is by accessing the web JSS. If you can login and view inventories and policies, I would say you're fine.
donmontalvo
Esteemed Contributor III
File service too, DNS, certs...
https://donmontalvo.com
yan1212
Contributor
To add to the above, in addition to checking your JSS config it is worth testing that your clients can still interact using the JAMF binary and Push Certs.
Specifically, if you can...
  1. Run policies that install packages over HTTP(S)/SMB/AFP successfully ( sudo jamf policy)
  2. Submit inventory successfully ( sudo jamf recon) and see the changes reflected in the JSS.
  3. Install software and/or Profiles via Self Service
..then you should generally be ok. You can always run these commands in verbose mode to get the whole story.
donmontalvo
Check MDM functions too, pushing Configuration Profiles...check VPP2/DEP...
