- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 06-18-2020 08:01 AM
I have a script that prompts a user for input using apple script for their name within my bash script. It seems to work great, but if they do not answer the prompt in about 1 min it prompts again because of a loop I have. Each time it prompts, another window appears on top of the other. So I either need to kill the dialog and I can't figure that out, or have my loop not keep trying every min and I'm not sure how do that either. Below is what my script looks like.
PromptDisplayName ()
DISPLAYNAME=$(/usr/bin/osascript << EOF
activate
set DISPLAYNAME to display dialog "Enter Full Name: " default answer "John Doe" with icon note buttons {"OK"} default button 1 with title "Enter Full Name"
return text returned of DISPLAYNAME as string
end tell
EOF
Loop until Displayname is in the correct format
until [[ "$DISPLAYNAME" =~ ([a-zA-Z]){3,}[[:blank:]]([a-zA-Z]+){3,} ]]
do
PromptDisplayName
done
Call on function to prompt user
PromptDisplayName
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-18-2020 08:56 AM
have a look at https://developer.apple.com/library/archive/documentation/LanguagesUtilities/Conceptual/MacAutomationScriptingGuide/DisplayDialogsandAlerts.html, in particular the 'giving up after X' part. This closes the dialog after X seconds. Choose X so its small enough for your repetition rate.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-18-2020 09:50 AM
Thanks mschoder! That did it. The bash loop was on a 2 min timer so I just added this to the end of my my applescript line, giving up after 119. See line below.
tell application "System Events" activate set DISPLAYNAME to display dialog "Enter Full Name: " default answer "John Doe" giving up after 119
