Help Removing Coral Painter Kext
dtmille2
Contributor III
Hi all, I need to remove this as part of troubleshooting a failed Corel Painter 2019 install: Library/StagedExtensions/System/Library/Extensions/PainterAudioDriver.kext. I am attempting to do so with "sudo rm -rf", but I am told I cannot as the operation is not permitted.
Anyone know another way to delete this file?
1 REPLY 1
dtmille2
Contributor III
I disabled SIP in recovery and was able to remove it.
