- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 07-31-2012 02:37 PM
Hello, I have a user who installed the latest and greatest Logitech mouse on his laptop. The preference pane is greyed out though and the user cannot access the software. I am new to Caspar and would like to allow the user to utilize the software. Any suggestions on how I go about setting this up?
I found the entries for the product "com.Logitech.ControlCenter.Preference.Pane" and "jp.plentycom.prefpane.SteerMouse"
Thanks for the help.
Joe
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2012 12:17 PM
In Workgroup Manager, under one of either User, Group, Computer or Computer Group, check under the Preferences button in the main toolbar, and then under System Preferences in the list of icons that shows up. That's where any Pref Pane management generally occurs with OD.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 07-31-2012 02:43 PM
Pref panes usually allow any user access to them even if they don't allow the user to make changes.
Is the pref pane greyed out before he clicks on it or are you saying the options in it are greyed out (no permission to make changes)?
I take it the user is not an administrator. What happens if an administrator installs it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 07-31-2012 02:46 PM
If you've set up MCX to restrict certain System Preference Panes with the allowedPreferencePanes option, then you'll need to add the Bundle Identifier into the array. I assume its "com.Logitech.ControlCenter.Preference.Pane" as you said in your post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-03-2012 02:47 PM
The preference pain is greyed out even though the user doing the install is an Administrator.
This might be the case, where is this set?
Joe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-03-2012 03:24 PM
yourJSS > Management > Managed Preferences
Look for something under com.apple.systempreferences. If you find that and see one called Enabled System Preference Panes" under it, click the Edit button to see the settings.
There will be a bunch of text inside an <array> block. Stuff like <string>com.apple.preference.datetime</string> for example. Those are the CFBundleIdentifer strings for the PrefPanes.
If that's all there, and these are being applied to your Macs, you need to add the bundle identifiers in for the logitech preference panes to unlock them. Alternatively, you could exclude some Macs from the scope of the managed preference from getting applied to them, but that would turn the whole MCX setting off for those Macs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2012 11:44 AM
Unfortunately this is completely empty. Any other suggestions as to where this might be set-up?
Joe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2012 11:53 AM
Were you using an Open Directory server before Casper that might still be applying managed settings to your Macs?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2012 11:55 AM
We are using open directory in addition to casper, but I am not aware of any settings with open directory that would be preventing this installation either.
Just so I can double check, where would I look in open directory to check for this?
Joe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-07-2012 01:51 PM
I found it earlier this afternoon, thanks for the advice. If I understand it correctly, I need to launch WorkGroup Manager from a machine where the software is installed and it should then allow me to add the appropriate preference panes, is that correct?
JOe
