How does "enrollment" trigger work for imaging?
cgiordano
Contributor
I have a, hopefully, simple question. It's something I just thought of and wanted to see if any one know...
If I have a policy set to trigger upon enrollment, how does that work for a machine that we image using Casper Imaging? Does it run during the FirstRun script that CI makes or will it trigger at first check-in after it's been fully booted up?
Thanks in advance!
Chris
2 REPLIES 2
bentoms
@cgiordano the 1st run script that Imaging creates includes enrolment. So I guess it would be after that.
cgiordano
Contributor
@bentoms Awesome! I can test it as well to confirm. Thanks very much Ben!
