Posted on 02-10-2014 07:43 AM
Hello
it looks like the EA/script for collecting Norton virus definition date does not work with SEP 12.1.4 (while it used to work fine here with up to SEP v. 12.1.2)
https://jamfnation.jamfsoftware.com/viewProductFile.html?id=29&fid=145
The reason seems to be they changed the location of the "WHATSNEW.TXT" file that is now within each updated definition (eg: /Library/Application Support/Symantec/AntiVirus/20140210.001/WHATSNEW.TXT) instead of /Library/Application Support/Symantec/AntiVirus/Engine/WHATSNEW.TXT"
I was wondering if anyones has found a way to use and extension attribute to collect virus definition dates for SEP 12.1.4.
Many thanks for your help!!!
Carlo
Posted on 02-10-2014 08:01 AM
Ugh, I am taking a look at that now since this is on my to-do list, and it looks like those paths are going to be changing often. There appears to be logic to the naming conventions but nothing I would rely on.
Plus, you will need to have code that can handle the old version and the new version if you have a mixed environment like I do. I'll start working on something unless someone else has a better idea than parsing all of the files and getting the most recent date.
Posted on 02-10-2014 08:02 AM
I am curious as to why you would waste your time with this when the SEPM should be able to report that stuff. I push all AV stuff to the teams that manage the AV servers.
The following works successfully with 12.1.4:
if [ -e "/Applications/Symantec Solutions/Symantec Endpoint Protection.app" ]; then
echo "<result>$(defaults read /Applications/"Symantec Solutions"/"Symantec Endpoint Protection".app/Contents/Info CFBundleShortVersionString)</result>"
echo "<result>N/A</result>"
Posted on 02-10-2014 08:33 AM
@josaxo][/url][/url][/url][/url][/url, that appears to just get you the app version.
Here is what I wrote (this needs more testing, I just threw this together), which actually gives me the integer version in days of the age of the definitions, which is more useful in my opinion. I can run a report or create a smart group to look for systems with defs that are older than our threshold and take automatic action based on that:
# Get age of SEP definitions
sepPath="/Library/Application Support/Symantec/Antivirus"
if [ -f "$sepPath/Engine/WHATSNEW.TXT" ]; then
result=`/bin/date -j -f "%b %d, %Y" "$(cat "/Library/Application Support/Symantec/AntiVirus/Engine/WHATSNEW.TXT" | grep "Symantec Security Response" | awk '{print $5, $6, $7}')" "+%s"`
for subDir in `ls "$sepPath"`; do
if [ -d "$sepPath/$subDir" ] && [ -f "$sepPath/$subDir/whatsnew.txt" ] ; then
subdefDate=`/bin/date -j -f "%b %d, %Y" "$(cat "$sepPath/$subDir/whatsnew.txt" | grep "Symantec Security Response" | awk '{print $5" " $6" " $7}')" "+%s"`
if [ $result ]; then
if [ $subdefDate -gt $result ]; then
result=$subdefDate
result=$subdefDate
done
curDate=`date "+%s"`
defAge=`echo $(((curDate - result)/60/60/24))`
echo "<result>$defAge</result>"
Posted on 02-10-2014 09:00 AM
My fault - I read the post too quickly.
Posted on 02-11-2014 05:12 AM
Yes, the SEPM can and does report it. However built-in security measures in OS X prevent live update from running when no one is logged into the system or the screen is locked. Consequently most of the systems on our 'out-of-date-more-than-5-days-report' are Macs. For us, there are industry requirements that we keep our Mac, Windows, and *nix systems up to date with whatever AV solution we use (and we have to use one) - so that's why I have to care. SEP 12.1.4 promises to fix the LU-not-running-with-no-console-user issue, but I have not really started testing that yet... To add insult to injury - if you try to force LU to run through the SEPM and it cannot because of one of the reasons above - it will become a zombie process and then LU will not run again until the Mac is restart or all LU processes are killed.
To that end I've written a number of scripts to force updates using Intelligent Update - it uses the built-in Installer binary to install a .pkg of def updates. A nightly job runs on one of our servers to curl the latest update package from Symantec, then distributes via casper syncing. A separate daily job runs on the Macs to curl that package from the internal servers and install. I don't want it applying to every Mac - because some actually do stay up to date - so that's why I care about an EA to tell me virus def dates. I wrote a blog article about it here: http://acdesigntech.wordpress.com/2012/01/18/live-update-does-not-run-when-no-user-is-logged-in-and-...
And these are the scripts I use to curl the latest updates and then the daily script to apply the latest update to a Mac:
## ServerSlipstream.sh written by Andrew Caldwell, 1/19/2012 ##
## This script pulls the latest virus defs from Symantecs website. ##
## And copies them to the Casper server. Also, deletes .pkgs ##
## older than 3 days. ##
mkdir -p -m 777 /Users/isdadmin/Desktop/SEP121Updates
## Clean up the SEP121Updates folder first. If the only file on Symantec's defs site is more than 3 days old, it will be redownloaded below for application to newly deployed clients
cd /Users/admin/Desktop/SEP121Updates/
CurrentTime=`date +%s` ## Get current time in seconds
Time3DaysAgo=$(($CurrentTime - (3 * 86400))) ## Get time 3 days ago in seconds
for i in `ls`; do ## delete update files modified more than 3 days prior to save space on the server
FileModTime=`stat -s $i | awk '{print $10}' | cut -d = -f2`
if [ "$FileModTime" -lt "$Time3DaysAgo" ]; then
## If the mod time is less, the file was modified more than 3 days ago, remove it
rm "$i"
done
## Repeat for the SEP121Updates folder on Casper server
cd /Volumes/CasperShare/SEP121Updates/
rm "$i"
done
## Get the current date. This will be used as a starting point to download the latest definitions
CurrDate=`date +%Y%m%d`
## A flag to signal the script when the update has been found and downloaded
UpdateFound=0
while [ $UpdateFound -eq 0 ]
do
## The filename is static except for the date it is released, so store this name in a variable
## to change if necessary
DesiredUpdate="NavM_Intel_Installer_"$CurrDate"_US.zip"
## Use curl to generate a listing of the files on the Symantec website. Grep out the file that most
## closely resembles the desired update, then clean it up so we have just the filename
RawFileListing=`curl -l ftp://ftp.symantec.com/public/english_us_canada/antivirus_definitions/norton_antivirus_mac/ | grep $DesiredUpdate`
## Compare the file curl found to the desired update filename. If they match, we've found the latest
## update, download it. If not, try again with the previous days' date
if [ "$RawFileListing" == "$DesiredUpdate" ]; then
UpdateFound=1
curl ftp://ftp.symantec.com/public/english_us_canada/antivirus_definitions/norton_antivirus_mac/$DesiredUpdate > /Users/admin/Desktop/SEP121Updates/$DesiredUpdate
cp /Users/admin/Desktop/SEP121Updates/$DesiredUpdate /Volumes/CasperShare/SEP121Updates/
## If we haven't found the update with $CurrDate, it must be for a previous date. Decrease the day by 1 to
## check again for an update file from the day prior
CurrDate=$(( $CurrDate - 1 ))
done
## SymantecIntelligentUpdate.sh written by Andrew Caldwell, 1/19/2012 ##
## This script pulls the latest virus defs from Symantecs website ##
## and installs them using Intelligent Updater. This script ensures ##
## Macs get the latest virus def updates even if no one is logged in ##
## kill live update if it is running
killall LiveUpdate
## Get the current date in YYYYMMDD format. This will be used as a starting point to download the latest definitions
UpdateFound=0
do
FileListing=`ls /Volumes/CasperShare/SEP121Updates | grep $DesiredUpdate`
if [ "$FileListing" == "$DesiredUpdate" ]; then
UpdateFound=1
cp /Volumes/"$CasperDP"/SEP121Updates/$DesiredUpdate /Users/Shared/
cd /Users/Shared/
unzip $DesiredUpdate
## Install the updates
installer -verbose -pkg SymantecAVDefs_Intel.pkg -target /
## If we haven't found the update with the current date, it must be a previous date. Decrease the day by 1 to
done
## Clean up after the updates are finished
rm -rf $DesiredUpdate SymantecAVDefs_Intel.pkg
Posted on 02-11-2014 08:34 AM
@alexjdale many thanks!
Now the EA works regardless of the installed SEP version
@everyone also many thanks for your other suggestions
Greetings
Carlo
