Posted on 10-03-2017 02:07 PM
When importing classes from ASM to JAMF, the first thing JAMF asks is "Site to Import Classes to".
It doesn't work (or doesn't do anything). After importing the class(es), all the class(es) sites are set to 'none'.
So what's the point? Would be helpful if it actually worked, but it doesn't.
JAMF JSS 9.101
Posted on 10-04-2017 12:20 PM
We're aware of this issue and have it filed under PI-004127.
The workaround is to change the JSS view to the site to which you want to import the Users & Classes and then import.
There is no ETA on a fix.
If you would like to get a case open and attached to PI-004127 or have additional questions about the Product Issue, please get in touch with Support either by giving us a call, sending an e-mail to support@jamf.com, or by using the My Support section of Jamf Nation.
Were Wulff
Jamf Support
