Posted on
01-17-2017
11:54 AM
- last edited
Tuesday
by
kh-richa_mig
Hello,
I am trying to follow this guide from JAMF: https://www.evernote.com/shard/s398/sh/bec8a262-e33d-4ad9-80fa-05b939db6d8d/f4ca396a63caa510
I am using the script noted here: https://www.evernote.com/shard/s398/sh/bec8a262-e33d-4ad9-80fa-05b939db6d8d/f4ca396a63caa510/res/916...
I got everything else working so far (you do need another policy to place the .dmg in the applications folder that the article neglects to tell you). I would like the script to force the restart instead of being "soft". I tested it and found that any open application will stop the upgrade.
Just need it to forcibly and immediately preform the restart.
Thanks.
Here is the script:
/Applications/Install macOS Sierra.app/Contents/Resources/startosinstall --applicationpath "/Applications/Install macOS Sierra.app" --volume $1 --rebootdelay 30 --nointeraction
killall "Self Service"
Posted on 06-27-2018 12:22 PM
@Rosko thanks very much for your help with this. I am starting back from scratch with the Sierra build and letting it go through the script to see what I can collect. I'll reply with what I find.
Posted on 06-28-2018 08:20 AM
@Rosko I found something in my install.log that hints at an issue with the targeted drive. Basically I am half completing the script and it upgrades to High Sierra but never converts to APFS (and finishes wiping the drive etc). The same situation as this post:
https://www.jamf.com/jamf-nation/discussions/26978/unable-to-upgrade-macos
I should also mention that I am running a bootcamp partition as these lab computers have the option to dual-boot into Windows if chosen.
Posted on 06-28-2018 10:30 AM
Is there a blog or wiki that explains how create a policy to use the script macOSUpgrade.sh created by @Rosko ?
I forgot if the Self Service policy should include a "Restart Options" or a restart by way of "Files and Process > Excute command". Or is the reboot already a function of
startosinstall
command?
Posted on 07-11-2018 10:11 AM
@alex030cc What directory did you place your launch agent in? I have FV2 Encrypted Macs and am looking to get this going with @Rosko 's script.
Posted on 07-12-2018 01:02 AM
Posted on 11-02-2018 08:16 AM
Just a quick note to say that when installing 10.12.6 via script to startosinstall in older versions(up to10.12.3) it had the --volume entry in the script which if removed makes the script work with Sierra 10.12.6. i.e.
startosinstall --volume / --applicationpath
change to
Had me fooled for a while.
Posted on 12-11-2018 02:28 PM
Thank you @Rosko for the effort and support you are putting into your script.
I am in the process of trying to deploy High Sierra via Self Service and was stuck for the longest time putting in the user variables.
It turns out, every time I tried to put in /Applications/Install macOS High Sierra.app in variable $4, the JSS would give an error and tell me to check the logs. Checking the logs, I find:
QueryException: Data too long for column 'parameter_1' at row 1
I presume this is MySQL barking at me.
Sure enough, if I put in a shorter path it works.
I am now trying it with the string hard-coded into the script.
Anybody else have issues with the user variables?
