Issue with two SSIDs in network config (Big Sur)
  • June 25, 2021
  • 0 replies
  • 13 views
In our environment, we have two different SSIDs, one for the 2.4 GHz band and one for the 5 GHz band. We authenticate with TLS using a certificate. Initially, we had only one SSID configured through Jamf and set to auto join. The certificates are also deployed in the same profile, which works fine. We would like our users to be able to switch between the SSIDs and be able to autojoin to both. When I add a second SSID into the configuration, the auto join functionality works fine and the Macs connect to one or the other, but if you try to manually swap over to the other SSID, it prompts you for enterprise credentials, and if you click cancel it still will connect. I just need to figure out how to get rid of this pop up as to not confuse end users.
