Jamf Connect Configuration Settings
  • June 25, 2021
  • 7 views
Is there a way to see what the current Jamf Connect Configuration settings are? I'm in the midst of upgrading to Jamf Connect 2.0 and the documentation on how to do so seems insufficient for me to be able to do so (new jamf admin here). I wish I could just download the older configuration, click it open to see it's settings but that doesn't seem to be the case. Any way to do this?
1 reply
  • June 25, 2021
There are multiple ways to check the current config.
  • Open the current config profile in jamf and check the application & custom settings payload.
  • Use an existing machine with the profile installed and navigate to system preferences > profiles > your jamf connect profile.
All configured settings should be listed there.
