Posted on 02-13-2025 11:55 PM
Solved! Go to Solution.
Posted on 02-14-2025 07:37 AM
@Shyamsundar Did you also change the password to the login keychain? If not this would be applicable: https://apple.stackexchange.com/questions/365101/how-to-change-the-password-of-a-local-admin-user-th...
And I have to comment, a 6-digit PIN is extremely short for a computer password. What's the logic for going from a password to a PIN?
Posted on 02-14-2025 09:01 AM
We migrated to PSSO with a secure enclave and wanted to use a PIN to log in to a Mac with a minimum of 6 digits. So it's easy for the users to log in to the Mac. As it's a local-only password and the Mac device has built-in brute force attack protection you need physical access to the Mac to crack the PIN
Windows Hello for Business utilizes a minimum 6-digit PIN to log in to the Windows device, we are trying to replicate the same for Mac users as well.
