JAMF Pro 11 Intergration with Cisco ISE 3.2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 02-11-2025 02:28 AM
Hi All,
We are planning JAMF Pro 11 integration with Cisco ISE version 3.2. I would like to know if it will support it and if we can have a step-by-step process for what needs to be done and how.
Please need the help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-11-2025 03:07 AM
Thanks,
Can you also help me with some links and also does JAMF server need import Cisco ISE CA.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-11-2025 11:09 AM
Yes, it supports it - however, it's we found it seems very finicky depending on the ISE patch version.
Have you started through the instructions? https://learn.jamf.com/en-US/bundle/technical-articles/page/Integrating_Jamf_Pro_with_Cisco_ISE_3-1....
I suspect your network engineer will be able to handle the heavy lifting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2025 09:36 AM - edited 02-14-2025 09:36 AM
Yes, Jamf Pro should be able to integrate with the minor versions (3.1, 3.2, etc.) of Cisco ISE 3. Our last technical document published was when 3.1 was the latest minor version. Cisco also publishes their own integration guides for using Jamf that can be found on their site: https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/220802-integrate-ise-3-...
