Posted on
05-19-2020
10:06 AM
- last edited on
03-04-2025
08:54 AM
by
kh-richa_mig
Hello
After the autoupdate to Skype 8.60, i have users getting an prompt to imput local admin credentials whenever they start Skype.
After some investigation, i concluded that skype wants access to a private key in the SYSTEM keychain, and the problem goes away if you just add it manually.
Does anyoane have any ideeas regardng how to solve this? I guess i will have a few hundred people having this problem and i have no clue how to solve it for everybody at once, and user by user is quite out of the question.
Posted on 05-19-2020 11:23 AM
Thank you for reporting this issue! This is the same problem many ran into with the Cisco AnyConnect Mobility Client. It took many versions and probably a lot of complaining to Cisco before they implemented a change to their console to add the option to stop traversing the System Keychain. Many have tried, lots of threads here in the forum, but it doesn't appear there's an easy-ish way to programmatically add the exception in Access Control.
Posted on 05-22-2020 06:14 AM
The issue is fixed by Microsoft. If you download Skype now it won't give this issue. They only didn't change the version number.
Posted on 05-22-2020 07:02 AM
Indeed, they fixed it . Good thing, because i could not find a valid workaround for the whole fleet of managed equipment.
Posted on 02-23-2022 05:50 AM
We have now similar issue with version 8.80.0.141, and downgrade to 8.79.0.95 also did not seemed to help.
Do you think we need to wait for fix from microsoft again?
Posted on 11-24-2024 11:03 AM
I confirm that the issue is back again. I tried every solution, found on the forums, but no avail.
