Jamf Pro 10.1 upgrade issues
PhillyPhoto
Valued Contributor
I upgraded my QA instance to Jamf Pro 10.1 today.
On a new machine, I tried to launch Imaging and I'm getting the following error when launching Jamf Imaging:
5142a989440f47d1be7b8d8f738f1e44
On an existing machine, it downloaded the new binary and upgraded Self Service, but has been hung executing a script all afternoon. In the console, it's just looping through the following:
Mon Dec 18 19:53:33 MYMACNAME jamf[1216]: Daemon starting Mon Dec 18 19:53:33 MYMACNAME jamf[1216]: The download of /Library/Application Support/JAMF/tmp/JamfBundle.tar.gz failed. Mon Dec 18 19:53:34 MYMACNAME jamf[1216]: Informing the JSS about login for user LOCALUSER Mon Dec 18 20:11:55 MYMACNAME jamf[4052]: Checking for policies triggered by "recurring check-in" for user "LOCALUSER"... Mon Dec 18 20:11:57 MYMACNAME jamf[4052]: Could not connect to the JSS. Looking for cached policies... Mon Dec 18 20:11:58 MYMACNAME jamf[4052]: Adding launchd task com.jamfsoftware.task.checkForTasks... Mon Dec 18 20:12:00 MYMACNAME jamf[4217]: An Error Occurred while attempting to manage the computer: Connection failure: "The Internet connection appears to be offline." Mon Dec 18 20:12:00 MYMACNAME jamf[4217]: Enforcing scheduled tasks... Mon Dec 18 20:12:00 MYMACNAME jamf[4217]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.1.plist... Mon Dec 18 20:12:01 MYMACNAME jamf[4217]: Adding launchd task com.jamfsoftware.task.1... Mon Dec 18 20:12:01 MYMACNAME jamf[1216]: Daemon shutdown completed Mon Dec 18 20:12:01 MYMACNAME jamf[1216]: Daemon exiting Mon Dec 18 20:12:01 MYMACNAME jamf[4217]: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.jamf.daemon.plist... Mon Dec 18 20:12:01 MYMACNAME jamf[4217]: Creating launch daemon... Mon Dec 18 20:12:01 MYMACNAME jamf[4217]: Creating launch agent... Mon Dec 18 20:12:01 MYMACNAME jamf[4217]: The management framework will be enforced as soon as all policies are done executing. Mon Dec 18 20:12:01 MYMACNAME jamf[4265]: Informing the JSS about login for user LOCALUSER Mon Dec 18 20:12:02 MYMACNAME jamf[4265]: Daemon starting Mon Dec 18 20:12:02 MYMACNAME jamf[4265]: The download of /Library/Application Support/JAMF/tmp/JamfBundle.tar.gz failed. Mon Dec 18 20:12:03 MYMACNAME jamf[4265]: Informing the JSS about login for user LOCALUSER
These are both on our internal network and have no problem accessing the JSS directly in Chrome.
I've opened a case as well, just wanted to throw it out there in case anyone else has seen this.
3 REPLIES 3
yahvi_rana
New Contributor II
Just adding my comments to stay in loop on this thread. Thanks
ImAMacGuy
Valued Contributor II
10.1 was removed from the upgrades because of some bugs...
Jamf notification
emily
Valued Contributor III
Looks like you might have a 10.1.1 to try and see if it works any better…
