Jamf Pro + Big Sur
rkeleghan
New Contributor III
Hi all
Just wondering .. what the min requirement of my JAMF Pro instance that I need to be on so I can support Big Sur with macOs management + pre-stage deployments?
4 REPLIES 4
mark_buffington
Contributor II
Contributor II
Based on progress we've tracked with the betas, you'll need to be on Jamf Pro 10.24+ in order to have successful enrollments with Big Sur.
sdagley
Esteemed Contributor
@rkeleghan Jamf Pro 10.25.1 would be recommended as it's the version that adds the Configuration profile payload that allows non-admin users approve Screen Recording
AJPinto
Honored Contributor
I was reading an article yesterday that said 10.22 was the minimum required for macOS 11, however I would go with 10.24 at lowest myself. 10.25 is too new for my taste, I am anything but a production beta tester or early adopter as others call it.
sdagley
You could use 10.24, but unless all of your Mac users are Admins you're going to have to build a Configuration Profile with something besides Jamf Pro, sign it, and then import it into your Jamf Pro instance so non-Admins will be to enable Screen Recording on Big Sur as the capability to create that payload in Jamf Pro didn't arrive until 10.25.1.
