Jamf Pro - Camera Settings - Shared iPads for Schools
  • June 25, 2018
  • 5 replies
  • 126 views
Hello all! First time posting on JAMF Nation. The strong community support is one of the reasons we’re considering JAMF.
We are currently on a trial period using JAMF Pro to manage our iPads in school.
Our iPads student iPads are currently shared iPads linked to Apple School Manager and our teachers iPads are not shared.
I’m not sure why but our student iPads are unable to access the camera settings (we’re trying to enable camera grid) however we can do so on the teachers iPad.
The students and teachers iPads have separate restrictions profile but “Allow Camera” is checked for both students and teacher’s restriontions profile. The students can use the camera and apps will ask for permission to use the camera too.
Is there something I’m missing?
Any help would be appreciatied.
  • June 25, 2018
Hi
What are you restricting are there any apps that use the camera restricted FaceTime etc You may find you are restricting something else that uses the camera also
If you do that then the camera will be disabled also
  • June 27, 2018
Hi @Aguiness !
Thank you so much for the response. We’re not restricting any applications currently.
Anything camera-related seems to be exactly the same as the restrictions on the teacher’s iPads’ configuration profile. I’ve attached screenshots.
If anyone notices a restriction that might be preventing camera settings access, feel free to point it out.
Thank you in advance!
  • November 30, 2021
I need this also! Strange how there is no camera settings on shared iPad? We're using Jamf School. Did you ever find a solution @erwin_c
  • November 30, 2021
Hi there!
Was not able to find the settings or a solution. Our school is now 1:1 iPad and no issues so it seems like it was a shared iPad thing. Apologies for not being able to give a more useful response.
  • November 30, 2021
Hi there!
😞no problem @erwin_c  thanks for the quick reply,
