JAMF Pro not updating system inventory
jzastrow
New Contributor III
I updated 4 MacBook's and a Studio that where still running macOS 12 about 3 weeks ago, and JAMF still show them running the old OS how can i force the full scan of the systems
1 ACCEPTED SOLUTION
AJPinto
Esteemed Contributor
Have you run "sudo jamf recon" on them? Devices should check in every 15 minutes and do a full poll weekly unless you have a workflow to make it happen more frequently.
3 REPLIES 3
AJPinto
howie_isaacks
Valued Contributor III
Unless someone deletes it, a Jamf Pro server will have a policy that runs an inventory daily. Do you have that policy? If not, you should create it and scope it to all of your computers. Do these Macs show any updated information such as new app installs and other data that an inventory would collect?
jzastrow
New Contributor III
@AJPinto
i did a sudo jamf recon script set to weekly
@howie_isaacks
think that is what happened will have to looking to creating a new one
