Posted on 10-17-2018 10:04 AM
So suddenly I get and error stating "There was an error updating the database schema"
Waiting on Jamf support to help but nothing yet.
We are running two Ubuntu VM's one for tomcat one for mySQL
Within the tomcat VM i can access the JAMF Pro via http but outside on my machine nothing.
the VM can ping out and the i turned off the firewall to see if I was blocking something suddenly but no go.
we were running fine for the past few weeks.
Posted on 10-17-2018 10:51 AM
Hi @anickless ,
I am the Technical Support Specialist assigned to the case, I will get a WebEx spun up and send you an invite in the next 5 minutes.
Best regards,
Ryan
Jamf Technical Support
