JSSDatabaseUtil - Could not execute with administrator privileges.
  • November 4, 2013
  • 6 replies
  • 26 views
Forum|alt.badge.img+15
I am in the process of setting up a test jss running 8.73. I built up the new machine and keep getting this error
when I try to run the JSSDatabaseUtil to restore the database.
I can run it from the command line, sudo java -jar JSSDatabaseUtil.jar, but something is off when I do that as well. It keeps complaining about using passwords from the command line and then the restore fails after about 15 minutes.
Anyone else see anything like this? I am not sure if this is due to java security settings or something with 8.73
Best answer by dwandro92
P.S. I'm sure you'll find that the restore was actually successful, and is only reporting failures because the password error returned a failure code
  • November 4, 2013
As far as the admin privileges error goes, try CDing to the database util's parent directory and verifying that your account (or group) has execute permissions with "ls -l". If not, you will have to use chown/chmod to fix your permissions. If that doesn't solve the problem, then it's probably a permissions issue on the MySQL side. As far as the password error is concerned, this isn't a huge deal. This error occurs because the JSSDatabaseUtil.jar file passes credentials to MySQL in order to restore the database. I was seeing this error as well and after a while it stopped doing it, but I'm not sure if I did something that stopped it or not.
  • November 4, 2013
  • November 5, 2013
Turns out I had to open a ticket with Jamf and the cause was Java 7. I downgraded to 6 and the JSSDatabaseUtil would work without complaining about the admin password. This issue has been fixed in 9 but is an issue in 8.73.
  • November 5, 2013
dwandro92 you were correct as well, I did have to increase the maximum_wait, and package sizes for the MySQL database then I was able to get a restore. It still threw that error but restored. The key was java 6 and not 7.
  • December 11, 2013
Is there a repo somewhere with Java SE JDK 6? Seem like oracle has EOL'd it and I need to do some testing and stage a server to test the JSS 8.73 - JSS 9.x jump. Thanks for your help!
  • December 11, 2013
Check http://www.oracle.com/technetwork/java/javase/downloads/java-archive-downloads-javase6-419409.html if you're using Windows or Linux. If you're using Mac Server, you have my condolences.
