Posted on 07-16-2019 02:03 PM
How does jamf identify Mac models?
Our newest Macs identify themselves as MacBook Pro (15-inch, 2019), but Jamf inventory shows them as MacBook Pro (15-inch, 2018).
Presumably Jamf will issue an update that fixes this problem, but in the meantime, is it possible to identify these models using an extension attribute, or some other method?
Posted on 07-16-2019 02:20 PM
Unfortunately, Apple is the source of this problem. For whatever reason the MacBookPro15,1 and MacBookPro15,2 model identifiers match both 2018 and 2019 Macs. This has happened before on the old-style MacBook Airs when they just got a minor processor bump, but it's definitely annoying on these new Pros.
For an EA to work, we'd need a unique component that is not shared with the 2018 models, the video card model number, perhaps?
Posted on 07-16-2019 02:54 PM
Pretty sure that's a Jamf update issue. So when the new version comes out, it can identify new models, etc.
Posted on 07-18-2019 05:52 AM
I found this bit of code returns the correct model name:
/usr/libexec/PlistBuddy -c "print :'CPU Names':$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}' | cut -c 9-)-en-US_US" ~/Library/Preferences/com.apple.SystemProfiler.plist
I found that here: https://apple.stackexchange.com/a/359753/41287
(The author of that comment actually included two different one-liners, the other of which returns the wrong model name on the 2019 MBPs.)
I'll wrap that up in an extension attribute.
Does anyone here know how Jamf itself determines the model?
Posted on 07-18-2019 07:49 AM
@stevenjklein Per Jamf Support, Jamf Pro utilizes the model identifier. Documented internally as PI-007140 "2019 MacBook Pros listed as 2018 models".
Posted on 07-18-2019 12:50 PM
The same behavior exists with:
It's just because the model identifier is identical. Think of it as a processor bump, as little else (often nothing else) changed about the new model.
Posted on 05-03-2020 07:26 PM
Where does macOS get the model name to display in the "About This Mac" dialog?
