macOS Control Center restriction location
  • May 23, 2023
  • 6 replies
  • 187 views
I have recently taken responsibility of jamf pro from a previous employee and have never really used it before so this is a learning experience. I have a Macbook Pro on Ventura OS in a computer group with a Staff Restrictions profile applied. This profile is somehow completely disabling Control Center and the ability to set a Screen Saver with the message "Control Center settings are not available. These settings are controlled by a profile." I can exclude the device from the profile and gain access to the Control Center and Screen Saver settings but not when it's applied. I figured these settings would be located under the Restrictions payload under Preferences but I see no such setting specifically targeting these. Does anyone know where / what is the setting that controls these? Is it another name or in another location? What am I missing? I see no specific setting to enable / disable. Thanks in advance
2_scoops_rice
  • July 26, 2023
Hi Vulpox,
I am also looking in restrictions and could not find anywhere to enable Control Center in Jamf Pro for macOS 13 Ventura. Please let me know if you found the setting for this. Thanks.
2_scoops_rice
  • July 27, 2023
Hi Vulpox,
I did a test and cloned the configuration profile and scope it specifically to my non-production MacBook Pro. In the restriction payload in the preferences tab I checked Parental Control and it enabled control center, battery, and screen saver in system settings. I hope this helps.
This issue is caused by having 'Time Machine' disabled in a restrictions payload. The is due to the fact that Control Center has options to add Time Machine to the menu bar.
Check this is not disabled in the payload:
To confirm.....this scenario only applies when you enable all selected items but exclude Time Machine.
st02264
  • August 27, 2024
Hi I was wondering if we can disable the control center on mac as I tried all possible way and yet cannot get JAMF to help in scenario no script or restriction helped to disable control center. ( mac snoma )
  • October 4, 2024
I enabled the TM setting, but still cannot get Control center to show up!  are there any other restrictions that might prevent this from showing up?
