Major Issues with 9.9+, Config Profiles and Spotlight issues
jpfromdc98
New Contributor III
I ran into this issue a couple of weeks ago and came to a similar conclusion. Everyone should check out MacMule's article. This is a solid explanation and resolution to the issue.
https://macmule.com/2016/05/09/icloud-spotlight-login-window-issues-with-jss-9-9-the-security-privacy-profile-payload/#more-2591
3 REPLIES 3
JustDeWon
Contributor III
Great find..
znilsson
Contributor II
I didn't even realize I was having the spotlight CPU issue until this post, which made me go look, and lo and behold, we're having the same issue. The fix outlined in the article fixed it for me, too.
gregleeper
New Contributor
This fixed Spotlight for me as well. Also, it was the only way I could reliably enforce the screen lock after sleep or screen saver. Thanks @bentoms for this.
