Managed Preferences for Users
  • October 15, 2014
  • 0 replies
  • 3 views
Hello, I am trying to find out if I am missing something, I am trying to use Managed Preferences through Casper to setup Chrome with settings to allow Kerebos (AuthServerWhitelist etc)
I enabled the checkbox on the Login/Logout Hooks settings in the JSS to allow managed prefs.
I uploaded the Google manifest and created the settings I wanted in Managed Preferences
Enabled the policy forced a computer to check in to the JSS via sudo jamf policy, as the documentation states the next time a computer checks in the settings will be applied.
No settings apply.
Logged off the computer, logged back in, no settings apply.
Tried another login, no settings apply type sudo jamf mcx -username loginname and the settings apply.
Not sure why it is not applying through a normal check in?
thanks for any information
JSS 9.51
Active Directory Users with mobile accounts
OSX 10.9.5 machines
david
