Management options Missing
  • December 2, 2014
  • 9 replies
  • 99 views
Hi all, I am currently having a strange issue here with trying to manage Yosemite imaged machines.
all current systems are on either OS X 10.8.x or 10.9.x and are managed via our JSS without issue.
The issue starts when I try to add a Yosemite machine.
Machines are present in JSS there are just have no MDM Capability as the Management Commands menu is
System Details:
All previous policies are in place New quickADD package created, JSS ( 9.61) Caper suite (9.6)
Can anyone think what may be causing the management commands to drop off?
  • December 3, 2014
No Thoughts?
  • December 3, 2014
Please reply with your results on the following Terminal items:
sudo jamf version
sudo jamf recon
sudo jamf manage -verbose -displayJSSTraffic
  • December 3, 2014
Justin, here are the results,
version=9.61
staff-nb-deploy:~ schmic$ sudo jamf version
version=9.61
staff-nb-deploy:~ schmic$ sudo jamf recon
Retrieving inventory preferences from https://mdm.xxxxxx.wa.edu.au:8443/...
Finding extension attributes...
Locating accounts...
Locating package receipts...
Locating applications...
Searching path: /Applications
Locating printers...
Locating hard drive information...
Locating hardware information (Mac OS X 10.10.0)...
Gathering application usage information...
Submitting data to https://mdm.xxxxxx:8443/...
<computer_id>377</computer_id>
staff-nb-deploy:~ schmic$ sudo jamf manage -verbose -displayJSSTraffic
Getting management framework from the JSS... Uploaded: 1 KB Downloaded: 2.6 KB Total Traffic: 3.6 KB
Enforcing management framework... verbose: Timeout: 60
Checking availability of https://mdm.xxxxxx.wa.edu.au:8443/... Uploaded: 969 bytes Downloaded: 1006 bytes Total Traffic: 1.9 KB
The JSS is available.
Enforcing login/logout hooks... verbose: Creating login hook... verbose: Enabling login hook... verbose: Creating logout hook... verbose: Enabling logout hook... verbose: Writing preferences for Login window... verbose: Creating startup item script... verbose: Created startup item script verbose: Creating launchd item for startup item... Uploaded: 962 bytes Downloaded: 8.2 KB Total Traffic: 9.2 KB Uploaded: 1 KB Downloaded: 894 bytes Total Traffic: 1.9 KB verbose: Attempting to install the mdm profile at the computer level.
The computer was successfully enrolled in MDM with the JSS.
Enforcing scheduled tasks... verbose: Removing existing launchd task /Library/LaunchDaemons/com.jamfsoftware.task.1.plist... verbose: Creating task Every 15 Minutes...
  • December 3, 2014
  • December 3, 2014
Thanks calumhunter, but I dont think that is the issue, could be wrong.
as thouse attributes are fine in JSS:
JSS Certificate Validation:Success
Verify Certificate Based Communication:Enabled
Verify MDM Enrollment:Enrolled
But under the General menu I have this:
MDM Capability:No
  • December 3, 2014
HI all,
At this point it looks like it may be a curupt quick add package causing issues.
i'll do some more testing and report back.
Cheers
davidacland
  • December 3, 2014
Hi, I've seen the "MDM Capability: No" symptom a few times, often when I'm setting up a new JSS. It's normally been a JSS config issue. As it is working ok for the other client Macs in your case I would feel comfortable saying the JSS config is working.
It's always possible that the network state of the Mac at the point of enrollment isn't quite right, stopping certain features from working.
That being said, I've had a few situations where recon has spat out a problematic QuickAdd package.
RobertHammen
Forum|alt.badge.img+29
  • December 3, 2014
sudo jamf removeMdmProfile
sudo jamf enroll -prompt
Does that fix the MDM Capability: No issue? Assuming it's working fine on other Macs. Does the Mac have a serial number available in About This Mac? Date/Time accurate?
  • December 10, 2014
Robert, No it did not fix the issue.
Time/Date were correct and there was a serial number displayed.
Turns out it was a combination of things.
  1. There was a certificate issue with the quickadd package
  2. Also an issue with the netboot server defaulting to a non-Yosemite netboot image through Deploy studio
Once these issues were sorted out, everythings seems to be working again.
