Posted on
11-01-2018
04:57 AM
- last edited
2 weeks ago
by
kh-richa_mig
So i've been using a script since the Jamf jump start which has been working a treat but recently its become sporadic and randomly works when it feels?!
I found that it adds a keychain entry for each drive and removing these was kicking it back in but now this isn't fixing it either.
Script is:
if [ "$3" == "" ]; then
user=/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'
user=$3
echo User logging in is $user
sudo -u $user /usr/local/jamf/bin/jamf mount -server "$4" -share "$5" -type "$6" -username "$user" -visible &
So I have separate policies to map each drive and these run based on AD memberships. (See attached screens)
Mapping the drives manually works fine so theres nothing wrong with users permissions or their group memberships its just these policies seem to pick and choose when they run and who they run for?!?!
Policie logs do show some differences but they all say completed and show no errors.(see attached screens)
Any ideas or changes to the script you can think i need?
Posted on 11-01-2018 05:19 AM
We have a script that does this and is ran from Self Service. The biggest difference is we use AppleScript to mount the share...
mount_volume() {
script_args="mount volume "${smb_mount}""
# If the home volume is unavailable take 2 attempts at (re)mounting it
tries=0
while ! [ -d /Volumes/${subject} ] && [ ${tries} -lt 2 ];
do
tries=$((${tries}+1))
sudo -u ${user_name} | osascript -e "${script_args}"
sleep 5
done
This is still working for us, so perhaps might be worth a try?
Posted on 11-01-2018 08:47 AM
How do you plug in different shares to that one script?
Posted on 11-01-2018 08:55 AM
Sorry, the full script was in the link, the code excerpt was simply the main difference. We are in the fortunate position of having a common naming scheme for server resources, full code for mounting is:
# College or support unit (chss, cmvm, csce, sg)
unit=$4
#unit="chss"
# Subject area or group
subject=$5
#subject="div"
user_name=`ls -l /dev/console | awk '{print $3}'`
smb_mount="smb://${user_name}@$unit.datastore.ed.ac.uk/$unit/$subject"
smb_path="smb://$unit.datastore.ed.ac.uk/$unit/$subject"
mount_volume() {
tries=0
do
sleep 5
done
if ! [ -d /Volumes/${subject} ]; then
mount_volume
exit 0;
