Posted on β07-25-2019 01:23 PM
So has anybody attempted to use the Mass Actions way to do an in place upgrade from 10.14.5 to 10.14.6
I was sent multiple white papers saying this is a way to perform an OS upgrade.
https://resources.jamf.com/documents/white-papers/simplified-macos-mojave-upgrade-workflow.pdf
and in this document on page 9.
https://resources.jamf.com/documents/books/apple-os-upgrades-guide-for-beginners.pdf
But when i attempt to do it nothing happens.
So i put in a ticket to Jamf, and i am told
"With those larger updates, it is usually recommended to upgrade with the installer app vs the remote command. Attached is a workflow a colleague made for this. Also, instead of using VPP, you can just package the installer with composer and push it out that way to the applications folder."
Posted on β07-26-2019 09:31 AM
And today I am told it is Product Issue PI-006005
i think it like the 10th one we have under our belts with none being fixed in over 3 years of having Jamf.
-Peter
