MDM Energy saver setting
Kallendal
New Contributor III
All,
Our organization has been using a MDM profile for Energy saver setting (see pic). Only option being used is "Wake for Ethernet network administrators’ access"
It seems anytime someone is making personal adjustments to their energy saver settings; these adjustments would reset after the Mac was restarted.
Removing the MDM profile for energy saver resolved it. Anyone have a good script work around to enforce the "Wake for Ethernet network administrators’ access" setting without a MDM Profile?
this would be on High Sierra, Mojave, and Catalina systems specifically (tested on all 3)
Much appreciated.
848f1c37b0904990a930aa94afe79599
1 REPLY 1
Devyn_Lowry
New Contributor II
Also having this problem, which is on Big Sur, have you found any solution to this?
