MFA solutions and Jamf
mwestaph
New Contributor
My organization uses Duo and we use their Mac Login app. I frequently have to reinstall it following macOS updates and find this to be a hassle.
Is this how it is with all MFA solutions that are installed in macOS? I only have experience with Duo and would appreciate it if others would share their experiences and recommendations if they have an MFA solution that doesn't require as much maintenance following macOS updates.
1 REPLY 1
AJPinto
Honored Contributor III
We use Jamf Connet paired with Okta for MFA and have never had any issues. However, I don't have any experience with Cisco Duo.
