Not able to open Jamf admin console
Rahulsoni24
New Contributor II
Dear all, I am facing an issue in accessing JAMF admin console with my credential. Same console is working fine for other admin member. i tried to validate the access but no difference in his and mine access. i have attached the error screen shot , please share your expertise to fix this issue. d39dc8cecf124cbea045257f8d86807e
5 REPLIES 5
ryan_ball
Valued Contributor
Can you manually mount the distribution point on that machine using the exact same user/pass set up in the Jamf Pro Server for that DP?
dgreening
Valued Contributor II
This has happened to me when the share is already mounted. Check you volumes list and eject it if it is mounted and re-try.
Rahulsoni24
New Contributor II
I don't see any mounted volumes named as CasperShare. Only system drive i can see under mounted volume.
franrayner
New Contributor II
Force quit Finder on your Mac or restart it, should resolve.
Rahulsoni24
New Contributor II
Thanks Franrayner, did reboot the MAC but still same. Other user is able to login without any issue.
