On-Prem Jamf: Remote Management is very slow. Is that normal?
sudoErase
Contributor
On-Prem Jamf: Remote Management is very slow. Is that normal? It takes about 30 ~ 1 hour, sometime even 24 hours to complete Remote Management.
We dont use Jamf cloud (cost reasons).
Anyone else using On-Prem, could you tell me how long it takes for your Remote management?
Is there any fixes around this? Technical documentation?
Thank you!
1 REPLY 1
AJPinto
Esteemed Contributor
Check your server resources, and network infrastructure. Those are the first things I would look at.
We are onprem right now ourselves, and considering moving to cloud. Yes the cost is a lot more, but onprem servers and maintaining those onprem servers is not free.
