Posted on
05-11-2019
05:36 PM
- last edited
3 weeks ago
by
kh-richa_mig
So I'm using built-in Jamf Patch Management to manage Microsoft OneDrive. According to the definition received from Jamf, the latest version (19.x) is supported on Mac OS X 10.11:
However, I'm seeing patching failures, because according to the installer states that macOS 10.12+ is required:
Sure enough, on https://macadmins.software site, the OneDrive minimum OS has changed:
So if you're OneDrive patch management policy is failing, that's why. I'll adjust my scope to account for this bug for now - does a support ticket need to be opened to get this definition fixed? Or does someone from Jamf monitor Jamf Nation for these types of discussions on patch management definition issues..?
~Ted
Solved! Go to Solution.
Posted on 05-11-2019 07:31 PM
Hello @taugust04 :
No need to make a support ticket, we'll get working on a fix for that immediately.
Sorry for the inconvenience and thank you for letting us know.
Jonny
Hello @taugust04 :
Jonny
