OSX Lion is a POS...Now SMB doesn't work!
Matt
Valued Contributor
So this after noon SMB just stopped working on 10.7.2. Tried a 10.7 machine same thing. 10.6.8 works like a champ.
Anyone else running into SMB issues. Lion is stressing me out.
Matt Lee, CCA/ACMT/ACPT/ACDT
Senior IT Analyst / Desktop Architecture Team / Apple S.M.E / JAMF Casper Administrator
Fox Networks Group
11 REPLIES 11
bentoms
10.7.2? Pre-release?
Regards,
Ben.
ernstcs
Contributor III
You're inspiring me to not touch Lion at all. =D
Fortunately, I have no hardware that requires it so I have time. Not deploying it for Fall, that's for sure.
Craig E
Not applicable
"The upcoming release of Mac OS X 10.7 Lion Server will remove the formerly bundled open source Samba software and replace it with Apple's own tools for Windows file sharing and network directory services, according to AppleInsider."
"However, "AppleInsider" says the Samba team has moved active development of the project to the more strict GPLv3 license, which prevents Apple from using the software commercially. Developers tell "AppleInsider" that Apple has internally announced that it will pull Samba from Mac OS X Lion and Lion Server, and replace it with Windows networking software developed by Apple."
There were A LOT of articles circulating the net well over two months ago that purported the absence of Samba from Lion.
Anyone tried using MacPorts to install Samba 3 on Lion?
Regards
Rhys.
Kedgar
Contributor
Looks like they did similar in Rhel 6... Everyone will most likely be
following suit.
Sent from Ken's iPhone
Mhomar
Contributor
We now know Samba is dropped and why, but has anybody figured out what and
how the “Apple” developed M$ networking is implemented yet?
Thanks
-- Michael J. Homar ? Apple Certified Associate
DSL, Desktop Support Team, GDC4S
8201 E. McDowell Rd., H707, Scottsdale, AZ 85257
Americas Infrastructure Services | p: 480-441-1106 | m: 480-209-8788 |
Michael.Homar at gdc4s.com | www.csc.com
Matt
Valued Contributor
Again this goes into my issues. How can we support an OS we know almost nothing about.
Fox Networks Group
bentoms
Guys, what issues are you seeing?
10.7 connecting to win2k8 r2 SMB shares works fine.
Mac is bound to domain, but was testing with a local account.
Regards,
Ben.
Matt
Valued Contributor
AD Binding works then doesn't allow anyone to connect. Dot is red but AD is Green.
Fox Networks Group
bentoms
So AD's not allowing login?
I can login using ad accounts on the same computer.
Didn't you mention that your servers do not have reverse lookup addresses? Will a hosts file help?
Regards,
Ben.
Matt
Valued Contributor
We checked with DNS and everything looks ok.
Fox Networks Group
bentoms
So if you do a host lookup of your domain, then lookup each return address. All reply?
Regards,
Ben.
