Just found this gem of info, hopefully someone else will find it useful.
http://prowiki.isc.upenn.edu/wiki/Enabling_Advanced_Logging_for_Wireless_in_Mac_OS_X
Duplicated (and cleaned up a bit) here in case the source goes away:
Airport and/or Wi-Fi Logging
sudo System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport debug +AllUserLand
2. Restart the Computer. - The wifi logs will be in Console in the /var/log/ subtree as wifi.log
Enabling eapolclient Logging (Authentication)
- ``` sudo defaults write /Library/Preferences/SystemConfiguration/com.apple.eapolclient LogFlags -int -1
- Restart the Computer.
The eapolclient is the 802.1X supplicant on Mac OS X. This setting will have it dump copious logs to /var/log/eapolclient.<interface>.log. Where the interface is something like en1, or whatever the particular network adaptor, wired or wireless, you're trying to use. You can also find them in Console.log
Note: To disable the logging you just set the integer back to 0
Using the Wi-Fi Utility in 10.8
To find it, navigate to: /System/Library/CoreServices/. From this utility you can:
•Create Diagnostic Report:
•Turn on debug logs
•Capture network traffic
{/quote}
