problems with nested smart configurations
agurley
New Contributor II
Anyone else having problems with Casper Imaging handling nested smart configs? It's creating two recovery partitions whenever I select a smart config whose parent is also a smart config. Was on Casper 9.12 and I'm not sure when the behavior started. My structure is as follows: Base config, then a smart config called "Deployed Macs" that uses Base, then a smart config under "Deployed Macs" called "Faculty Macs." When I choose the 1st-level smart configuration in Casper Imaging I see that the correct partitions will be created (mac hd and recovery), but when I choose the 2nd-level "Faculty Macs" it's creating two recovery partitions. I upgraded to Casper 9.22 and it's doing the same thing. As a workaround I ditched the nested smart config and created it as another smart config, one-level under the base, which is fine, but thought I'd share that this is happening in my environment. Am I missing something obvious?
3 REPLIES 3
bentoms
@agurley, how are you creating the recovery partition?
Also, have you seen this on more than one Mac?
Josh_S
Contributor III
This behavior is a confirmed defect:
D-006001: Multi-nested configurations duplicate partitions set in the parent configuration
leegalan
New Contributor III
Any idea if this is going to be fixed soon?
