Posted on 04-19-2021 12:22 PM
Is there a way to push unique client cert per device for a proxy without having to create a configuration profile per user?
Posted on 04-19-2021 12:40 PM
@user-kgvShFwdkY If you've got a SCEP or Venafi system you can have Jamf Pro use a Payload Variable (see Payload Variables for Configuration Profiles) to use the user name or computer name as the name of the certificate to be installed.
Posted on 04-23-2021 08:38 PM
Thanks, let me try this!
