remote login disabling using profiles
  • December 11, 2023
  • 4 replies
  • 186 views
hello all, does anyone know how to disable remote login using a profile/policy
  • December 11, 2023
The terminal command for disabling remote login is:
sudo systemsetup -f -setremotelogin off
So you should be able to create a policy with that line in Files and Processes > Execute Command to disable remote login on a computer.
  • December 11, 2023
(Except no sudo, since Jamf is executing as root already.)
AJPinto
  • December 12, 2023
The command @mdp should get the job done. However using the enable/disable Remote Desktop MDM command in under the Macs inventory record > Management > Management Commands is much faster. You can also issue the MDM command as a mass action.
  • March 1, 2024
I have a similar need to the OP and found this thread. Thanks so much!
I am going to assume from this that there isn't a config profile method that can be utilized to limit the removal?
