Removing Office 2011
g1za
New Contributor III
How would i completely remove Office 2011 on a network via Casper/JSS?
I've found the 12 step guide to removing the software from Microsoft: http://support.microsoft.com/kb/2398768/en-us
Would i do this while running composer to create a package and send out?
40 REPLIES 40
jhuls
Contributor III
So, I'm trying to use Paul's script and have two questions...
  1. Can I just paste this into Jamf and run as a script or do I need to make some adjustments? I'm not an expert on scripting but noticed $1 and $2 and am wondering if I need to change those lines to something like $4 and $5? Above someone mentioned changing $1 to $4 on specific line but the script I'm looking at doesn't have that on that line number and there's more than one.
  2. I haven't had luck with dockutil removing items when the path is in there like it is. It says it's not found. Anybody else have this work or do I need to go in and edit the script to use the dock icon names?
Sorry for digging up an old thread but it seems to apply.
