Posted on
03-20-2019
03:39 AM
- last edited on
03-04-2025
09:19 AM
by
kh-richa_mig
Hi mates.
I have an rsync running with this command:
/usr/bin/rsync -avbz --no-p --no-g --chmod=ugo=rwX --update --delete --ignore-errors --force
--backup-dir="Deleted-$DATE"
--exclude='.*' --exclude='Applications' --exclude='Downloads' --exclude='Library'
--exclude='Movies' --exclude='Music' --exclude='Pictures' --exclude='Public'
--exclude='Music' --progress --log-file="$log"
"/Users/$currentUser/" "/Volumes/$share/Backup/"
Basically does what it should do, like creating a Deleted-folder with current date suffix and move the stuff deleted on the source to there - so far so good.
However, when it runs next time, it would create a new Deleted-folder and move the previously created Deleted-folder within it, likely because this Deleted-folder is obviously not present on the source at all (as it never was, in this form). This "nesting" would multiply the needed storage with each run, which I would obviously like to prevent.
Is there any nice attribute I am currently not aware of to leave the existing Deleted-folders on the destination untouched, not copying them again and again to new Deleted-folders?
Hope my attempt to explain in conjunction with the screenshot attached makes it clear what my problem looks like...
Thanks and best regards,
Christian
Solved! Go to Solution.
Posted on 03-21-2019 06:38 AM
ryan.ball, I just found it out myself... had to exclude 'Deleted-*' as well, and it works like a charm. Thank you. :-)
Posted on 03-20-2019 08:03 AM
@cbednarzwd What happens if you run it like this multiple times:
--backup-dir='Deleted Previously'
