Posted on
04-17-2019
09:37 PM
- last edited
3 weeks ago
by
kh-richa_mig
Hi
i have configured a pac file and pushed using jamf pro
google chrome works as expected the network user is prompted for their credentials and all ok but with safari the mac tries to open up system prefs the for the user to enter credentials works fine for local admin but not for network users any ideas
i have tried using specific proxy targets also
Posted on 04-19-2019 06:45 PM
The pop up for safari is so you can first authenticate to the proxy but also add a keychain item to your login keychain. This way anytime the proxy needs login and password info safari can get it right from the keychain and then not prompt the user.
