- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 06-14-2016 01:10 AM
I've set up a Software Update Server and pointed clients at it in the JSS. This seems to work fine on most clients, but on a few it's still going to Apple / App Store for updates.
if I run the command to check where it's pointed:
sudo defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
I get this response every time:
The domain/default pair of (/Library/Preferences/com.apple.SoftwareUpdate, CatalogURL) does not exist
This is on El Cap and Yosemite clients. Not sure if it's something wrong with that command, I'd expect it to return something?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-14-2016 02:33 AM
That response means the value isn't set, which is the case on my Mac so I would assume that means "get updates from Apple".
How are you setting the SUS address? Are you able to verify if the setting has been applied to all devices?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-14-2016 03:11 AM
Thank you for responding David.
I've established the cause and rectified it now - my colleague had deployed via a policy applied to a smart group. The criteria needed tweaking to include the affected Macs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
