Posted on
10-13-2017
06:42 AM
- last edited on
03-04-2025
07:05 AM
by
kh-richa_mig
I'm looking for a way to create a smart group based on the URI of a printer.
For example, if the URI of a printer is ipp://127.0.0.1, I would want a smart group that looks for any printers with 127.0. in it.
Is this possible at all, maybe with an extension attribute?
Solved! Go to Solution.
Posted on 10-13-2017 08:49 AM
You could create a smart group using the criteria "Printers Mapped is <nameOfPrinter>" but if you want to specifically target the URI then you would need an extension attribute. After a quick look, it would appear this would actually be pretty straightforward as we can utilize lpstat to get printer information from client machines. Here's a quick and dirty way you could do this:
printerURI="ipp://127.0.0.1"
isInstalled="False"
if [ "$(lpstat -p -v | grep $printerURI)" ] ; then
isInstalled="True"
echo "<result>$isInstalled</result">
You can change printerURI to "printerURI=$4" and then define the printer URI within the JSS script parameters instead of hardcoding it. The above example is far from robust or exhaustive, but you get the idea :)
isInstalled="False"
isInstalled="True"
Posted on 10-13-2017 12:44 PM
Thanks! Solved.
