3 weeks ago
Hi all, is it possible to create a smart group with membership based on Entra ID platform SSO registration? That is, devices where a user has gone through the SSO registration process by selecting the Company Portal notification.
I'm rolling out Platform SSO to our devices and am in need of a way to group which devices have SSO registered so we know which ones can be signed in by any organisation user, and also just to verify that it's enabled on devices we're pushing it to.
3 weeks ago
Is this what you are looking for? I sniped it some years ago, the credit is in the comments but I dont remmeber where I got it from.
#Written by Ben Whitis - 08/11/2022
#get user
loggedInUser=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
#check if wpj private key is present
WPJKey=$(security dump /Users/$loggedInUser/Library/Keychains/login.keychain-db | grep MS-ORGANIZATION-ACCESS)
if [ ! -z "$WPJKey" ]
then
#WPJ key is present
#check if jamfAAD plist exists
plist="/Users/$loggedInUser/Library/Preferences/com.jamf.management.jamfAAD.plist"
if [ ! -f "$plist" ]; then
#plist doesn't exist
echo "<result>WPJ Key present, JamfAAD PLIST missing</result>"
#PLIST exists. Check if jamfAAD has acquired AAD ID
AAD_ID=$(defaults read /Users/$loggedInUser/Library/Preferences/com.jamf.management.jamfAAD.plist have_an_Azure_id)
echo "$AAD_ID"
if [[ $AAD_ID -eq "1" ]]; then
#jamfAAD ID exists
echo "<result>Registered</result>"
#WPJ is present but no AAD ID acquired:
echo "<result>WPJ Key Present. AAD ID not acquired</result>"
#no wpj key
echo "<result>Not Registered</result>"
3 weeks ago
3 weeks ago
Please refer to the below to check if the user is also registered on device compliance post SSO registration
#Updated 11/29/2023 - use dscl to identify user home directory for scenarios where loggedInUser is an alias
#Updated 10/10/2024 - added support for platformSSO referencing @robjschroeder's EA
#get user
#get user home directory
userHome=$(dscl . read "/Users/$loggedInUser" NFSHomeDirectory | awk -F ' ' '{print $2}')
#check if registered via PSSO:
platformStatus=$( su $loggedInUser -c "app-sso platform -s" | grep 'registration' | /usr/bin/awk '{ print $3 }' | sed 's/,//' )
if [[ "${platformStatus}" == "true" ]]; then
#Check if jamfAAD registered too
psso_AAD_ID=$(defaults read "$userHome/Library/Preferences/com.jamf.management.jamfAAD.plist" have_an_Azure_id 2>/dev/null)
if [[ $psso_AAD_ID -eq "1" ]]; then
#jamfAAD ID exists
echo "<result>Registered with Platform SSO - $userHome</result>"
#PSSO registered but not jamfAAD registered
echo "<result>Platform SSO registered but AAD ID not acquired for user home: $userHome</result>"
WPJKey=$(security dump "$userHome/Library/Keychains/login.keychain-db" | grep MS-ORGANIZATION-ACCESS)
then
#WPJ key is present
plist="$userHome/Library/Preferences/com.jamf.management.jamfAAD.plist"
echo "<result>WPJ Key present, JamfAAD PLIST missing from user home: $userHome</result>"
AAD_ID=$(defaults read "$userHome/Library/Preferences/com.jamf.management.jamfAAD.plist" have_an_Azure_id)
#jamfAAD ID exists
echo "<result>Registered - $userHome</result>"
echo "<result>WPJ Key Present. AAD ID not acquired for user home: $userHome</result>"
#no wpj key
echo "<result>Not Registered for user home $userHome</result>"
