Posted on β10-29-2020 01:22 AM
Dear all.
Is anyone of you aware of a way how to prevent
the auto-starting of Teamviewer (and with that, the basic setup assistant) after the installation?
I have seen that there are quite a few Launch agents and Launch Daemons included in the installer package, but I don't really know how to manipulate the portions in there to just block the auto start after installation.
Any idea? Thanks a million.
Cheers
Chris
Solved! Go to Solution.
Posted on β10-29-2020 05:18 AM
@Chris , whoah, that was a quick solution. Splendid. Thanks!
Posted on β10-29-2020 02:04 AM
Posted on β10-29-2020 05:17 AM
Posted on β11-23-2020 06:34 AM
Is there anyway to preconfigure the unattended access window? I've built a .dmg for the installer and set FUT and FEU, but on a new install the popup is launched upon first run of TeamViewer.
Posted on β11-25-2020 02:31 AM
@Jason33 I think there is simply no way/no sense to bypass this, as you cannot pre-allow things like screen recording, by OS design (privacy and user consent).
